Posted by member Marvarino on Thursday 13 November 2025
I am also new to this. I am considering changing my AQ151c petrol engine for Volvo Penta TAMD31A 130hp Marine Diesel Engine. If it is too much trouble I probably won’t? The out drive is vp 290sx. Does anyone know if this engine will fit with not too many modifications. The boat is a circa 1989 Hardy 25. I don’t have any problems with the current engine, I think it may be more economical and possibly more reliable in the long term. Any advice would greatly help. Thanks Steve.
Posted by member Simon bradbury on Monday 27 June 2022
Hi Peter I have a wooden spoked wheel on my hardy 25 is that what you are looking for if so would trade for your metal wheel. Kind regards Simon
Posted by member julian knapp on Wednesday 3 June 2020
thanks - I know of them and have dealt with them for spares in the past.
Posted by member Calum on Wednesday 3 June 2020
Hi Julian,
Might be worth talking to lancing marine. They do a lot of marinising parts for different engines and have a lot of experience in the field. For example they advertise a Ford fsd engine which i believe is basically the ford transit 2.5 DI engine. They have it rated at 65hp but it was available in higher, they also state it is suitable for stern drive applications. These engines would be cheap to find and run, indeed I have one fitted in my series 2a landie. Been there for last fifteen years with no issues whatsoever and still going strong. Good luck with your search.
Posted by member julian knapp on Tuesday 2 June 2020
Thanks - I will provide more info when I have taken over
Use will be inland rivers only but I wouldn't want my "conversion" to limit its potential
All parts will need to s/h to keep costs down - either bought rebuilt or bought and then rebuilt by me
Current install is a Volvo AQ151C and Volvo stern drive (exact details not known)
I'm going to use the existing configuration whilst parts are sourced even if that takes 12 months....time is not a major issue
More to come.............
Posted by member julian on Monday 25 May 2020
Sorry I should have said - I want to fit a Diesel engine
I am new to this forum and about to be come the owner of a Hardy 25 with a petrol engine
Is there an established "standard" easy swap over engine solution as there is with small Freemans
The current installation is a Volvo Penta AQ petrol engine and stern drive - to further show my ignorance is the sterndrive also the gearbox leaving me needing a short engine or do I need an engine and box?
Any advice would be much appreciated as would advice on where to source and who might fit
Post purchase the boat will be being moved by road and it might make sense for it to go to someone en-route to do this job before it gets to me
I tried to post this this morning but something went wrong so apologies if two posts appear - it will be interesting to see how similar they are!
KR to all Julian
